gmarluci
TUTORIAL Teclas de Atalho
Windows Vista – Keyboard Shortcuts:
Right SHIFT for eight seconds - Turn Filter Keys on and off
Left ALT+left SHIFT+PRINT SCREEN (or PRTSCRN) - Turn High Contrast on or off
Left ALT+left SHIFT+NUM LOCK - Turn Mouse Keys on or off
SHIFT five times - Turn Sticky Keys on or off
NUM LOCK for five seconds - Turn Toggle Keys on or off
Windows logo key +U - Open the Ease of Access Center
General Keyboard Shortcuts:
F1 - Display Help
CTRL+C - Copy the selected item
CTRL+X - Cut the selected item
CTRL+V - Paste the selected item
CTRL+Z - Undo an action
CTRL+Y - Redo an action
DELETE - Delete the selected item and move it to the Recycle Bin
SHIFT+DELETE - Delete the selected item without moving it to the Recycle Bin first
F2 - Rename the selected item
CTRL+RIGHT ARROW - Move the cursor to the beginning of the next word
CTRL+LEFT ARROW - Move the cursor to the beginning of the previous word
CTRL+DOWN ARROW - Move the cursor to the beginning of the next paragraph
CTRL+UP ARROW - Move the cursor to the beginning of the previous paragraph
CTRL+SHIFT with an arrow key - Select a block of text
SHIFT with any arrow key - Select more than one item in a window or on the desktop, or select text within a document
CTRL with any arrow key+SPACEBAR - Select multiple individual items in a window or on the desktop
CTRL+A - Select all items in a document or window
F3 - Search for a file or folder
ALT+ENTER - Display properties for the selected item
ALT+F4 - Close the active item, or exit the active program
ALT+SPACEBAR - Open the shortcut menu for the active window
CTRL+F4 - Close the active document (in programs that allow you to have multiple documents open simultaneously)
ALT+TAB - Switch between open items
CTRL+ALT+TAB - Use the arrow keys to switch between open items
CTRL+Mouse scroll wheel - Change the size of icons on the desktop
Windows logo key +TAB - Cycle through programs on the taskbar by using Windows Flip 3-D
CTRL+Windows logo key +TAB - Use the arrow keys to cycle through programs on the taskbar by using Windows Flip 3-D
ALT+ESC - Cycle through items in the order in which they were opened
F6 - Cycle through screen elements in a window or on the desktop
F4 - Display the Address bar list in Windows Explorer
SHIFT+F10 - Display the shortcut menu for the selected item
CTRL+ESC - Open the Start menu
ALT+underlined letter - Display the corresponding menu
ALT+underlined letter - Perform the menu command (or other underlined command)
F10 - Activate the menu bar in the active program
RIGHT ARROW - Open the next menu to the right, or open a submenu
LEFT ARROW - Open the next menu to the left, or close a submenu
F5 - Refresh the active window
ALT+UP ARROW - View the folder one level up in Windows Explorer
ESC - Cancel the current task
CTRL+SHIFT+ESC - Open Task Manager
SHIFT when you insert a CD - Prevent the CD from automatically playing
Dialog Box Keyboard Shortcuts:
CTRL+TAB - Move forward through tabs
CTRL+SHIFT+TAB - Move back through tabs
TAB - Move forward through options
SHIFT+TAB - Move back through options
ALT+underlined letter - Perform the command (or select the option) that goes with that letter
ENTER - Replaces clicking the mouse for many selected commands
SPACEBAR - Select or clear the check box if the active option is a check box
Arrow keys - Select a button if the active option is a group of option buttons
F1 - Display Help
F4 - Display the items in the active list
Microsoft Windows Logo Keyboard Shortcuts:
Windows logo key - Open or close the Start menu
Windows logo key +PAUSE - Display the System Properties dialog box
Windows logo key +D - Display the desktop
Windows logo key +M - Minimize all windows
Windows logo key +SHIFT+M - Restore minimized windows to the desktop
Windows logo key +E - Open Computer
Windows logo key +F - Search for a file or folder
CTRL+Windows logo key +F - Search for computers (if you are on a network)
Windows logo key +L - Lock your computer or switch users
Windows logo key +R - Open the Run dialog box
Windows logo key +T - Cycle through programs on the taskbar
Windows logo key +SPACEBAR - Bring all gadgets to the front and select Windows Sidebar
Windows logo key +G - Cycle through Sidebar gadgets
Windows logo key +U - Open Ease of Access Center
Windows logo key +X - Open Windows Mobility Center
Windows logo key with any number key - Open the Quick Launch shortcut that is in the position that corresponds to the number. For example, Windows logo key +1 to launch the first shortcut in the Quick Launch menu.
Windows Explorer Keyboard Shortcuts:
CTRL+N - Open a new window
END - Display the bottom of the active window
HOME - Display the top of the active window
F11 - Maximize or minimize the active window
NUM LOCK+ASTERISK (*) on numeric keypad - Display all subfolders under the selected folder
NUM LOCK+PLUS SIGN (+) on numeric keypad - Display the contents of the selected folder
NUM LOCK+MINUS SIGN (-) on numeric keypad - Collapse the selected folder
LEFT ARROW - Collapse the current selection (if it is expanded), or select the parent folder
ALT+LEFT ARROW - View the previous folder
RIGHT ARROW - Display the current selection (if it is collapsed), or select the first subfolder
ALT+RIGHT ARROW - View the next folder
CTRL+Mouse scroll wheel - Change the size and appearance of file and folder icons
ALT+D - Select the Address bar
Windows Sidebar Keyboard Shortcuts:
Windows logo key +SPACEBAR - Bring all gadgets to the front and select Sidebar
TAB - Cycle through Sidebar controls
Windows Photo Gallery Keyboard Shortcuts:
CTRL+F - Open the Fix pane
CTRL+P - Print the selected picture
ENTER - View the selected picture at a larger size
CTRL+I - Open or close the Details pane
CTRL+PERIOD (.) - Rotate the picture clockwise
CTRL+COMMA (,) - Rotate the picture counter-clockwise
CTRL+E - Search for an item
ALT+LEFT ARROW - Go back
ALT+RIGHT ARROW - Go forward
PLUS SIGN (+) - Zoom in or resize the picture thumbnail
MINUS SIGN (-) - Zoom out or resize the picture thumbnail
CTRL+Mouse scroll wheel - Change the size of the picture thumbnail
CTRL+B - Best fit
LEFT ARROW - Select the previous item
DOWN ARROW - Select the next item or row
UP ARROW - Previous item (Easel) or previous row (Thumbnail)
PAGE UP - Previous screen
PAGE DOWN - Next screen
HOME - Select the first item
END - Select the last item
DELETE - Move the selected item to the Recycle Bin
SHIFT+DELETE - Permanently delete the selected item
LEFT ARROW - Collapse node
RIGHT ARROW - Expand node
Keyboard Shortcuts For Working With Movie Maker Videos:
J - Move back one frame
K - Pause the playback
L - Move forward one frame
I - Set the start trim point
O - Set the end trim point
M - Split a clip
HOME - Stop and rewind all the way back to the start trim point
ALT+RIGHT ARROW - Advance to the next frame
ALT+LEFT ARROW - Go back to the previous frame
CTRL+K - Stop and rewind playback
CTRL+P - Play from the current location
HOME - Move the start trim point
END - Move to the end trim point
PAGE UP - Seek to nearest split point before the current location
PAGE DOWN - Seek to nearest split point after the current location
Windows Help Viewer Keyboard Shortcuts:
ALT+C - Display the Table of Contents
ALT+N - Display the Connection Settings menu
F10 - Display the Options menu
ALT+LEFT ARROW - Move back to the previously viewed topic
ALT+RIGHT ARROW - Move forward to the next (previously viewed) topic
ALT+A - Display the customer support page
ALT+HOME - Display the Help and Support home page
HOME - Move the to beginning of a topic
END - Move to the end of a topic
CTRL+F - Search the current topic
CTRL+P - Print a topic
F3 - Move to the Search box.
Marc Liron – Microsoft MVP
www.marctalkstech.com/guides.html
Windows Vista
Atalhos de Teclado - Atalhos para acessibilidade:
SHIFT da direita por 8 segundos - liga e desliga teclas de filtragem
ALT esquerdo + SHIFT esquerdo + PRINT SCREEN (ou PrtScrn) - ativa e desativa o alto contraste de tela
ALT esquerdo + SHIFT esquerdo + NUM LOCK - ativa ou desativa as teclas do mouse
SHIFT cinco vezes - ativa ou sesativa as teclas de aderência
NUM LOCK por cinco segundos - ativa ou desativa todas as teclas de alternância
Tecla Windows + U - abre o Centro de Facilidade de Acesso do Windows Vista
Atalhos básicos:
F1 - chama a ajuda do sistema, ou do programa em foco
CTRL+C - copia para a área de transferência
CTRL+X - corta para a área de transferência
CTRL+V - cola a partir da área de transferência
CTRL+Z - desfaz uma ação
CTRL+Y - refaz uma ação
DELETE - apaga o item selecionado e o enviar à lixeira
SHIFT+DELETE - apaga o item selecionado sem o enviar à lixeira
F2 - renomeia o item selecionado
CTRL+Seta para a direita - move o cursor para o começo da próxima palavra
CTRL+Seta para a esquerda - move o cursor para o começo da palavra anterior
CTRL+Seta para baixo - move o cursor para o começo do próximo parágrafo
CTRL+Seta para cima- move o cursor para o começo do parágrafo anterior
CTRL+SHIFT com qualquer tecla de direção - seleciona um bloco de texto
SHIFT com qualquer tecla de direção - seleciona mais de um item em uma janela ou na área de trabalho, ou seleciona texto dentro de um documento
CTRL com qualquer tecla de direção+Barra de Espaço - seleciona itens individuais simultâneos em uma janela ou na área de trabalho
CTRL+A - seleciona todos os itens em um programa ou documento aberto
F3 - busca um arquivo ou pasta
ALT+ENTER - mostra as propriedades de um determinado item
ALT+F4 - fecha o item ativo ou o programa em execução
ALT+Barra de Espaço - abre o menu de atalhos para a janela ativa
CTRL+F4 - fecha o documento ativo (em programas que permitem mais de um documento aberto simultaneamente)
ALT+TAB - alterna entre os itens abertos
CTRL+ALT+TAB - usa as teclas de direção para alternar entre os itens abertos
CTRL+"rodinha" do mouse - altera o tamanho dos ícones na área de trabalho
Tecla Windows +TAB - alterna entre os programas da barra de tarefas queo o efeito Windows Flip 3-D estiver ativado
CTRL+Tecla Windows+TAB - usa as setas de direção para alternar entre os programas da barra de tarefas queo o efeito Windows Flip 3-D estiver ativado
ALT+ESC - alterna entre itens na ordem em que foram abertos
F6 - alterna entre elementos de tela em uma janela ou na área de trabalho
F4 - mostra a lista da barra de endereços no Windows Explorer
SHIFT+F10 - mostra o menu de atalhos para o item selecionado
CTRL+ESC - abrir o menu Iniciar
ALT+letra sublinhada - mostra o menu correspondente
F10 - ativa a barra de menus no programa atual
Seta para a direita - abrir o próximo menu à direita ou um submenu
Seta para a esquerda - abrir o próximo menu à esquerda ou fechar o submenu
F5 - atualizae o a janela ativa
ALT+Seta para cima - visualizar a pasta um nível acima no one level up in Windows Explorer
ESC - cancela a tarefa atual
CTRL+SHIFT+ESC - abre o Gerenciador de Tarefas
SHIFT ao inserir um CD - evitar que o CD seja reproduzido automaticamente
Atalhos em caixas de diálogo:
CTRL+TAB - seleciona a próxima guia
CTRL+SHIFT+TAB - seleciona a guia anterior
TAB - seleciona a próxima opção
SHIFT+TAB - seleciona a opção anterior
ALT+letra sublinhada - iniciar comando (ou selecionar uma opção) que começa com aquela letra
ENTER - pode ser usado no lugar do clique do mouse
Barra de Espaço - seleciona ou limpa o check box selecionado
Teclas de direção - seleciona um botão na tela
F1 - mostra a Ajuda
F4 - mostra os itens da lista atual
Atalhos relativos à tecla Windows:
Tecla Windows - abrir ou fechar o menu Iniciar
Tecla Windows +PAUSE - mostra a caixa de diálogo Propriedades do Sistema
Tecla Windows +D - mostra a área de trabalho
Tecla Windows +M - minimiza todas as janelas
Tecla Windows +SHIFT+M - restaura as janelas minimizadas
Tecla Windows +E - abrir a janela Computador
Tecla Windows +F - procura por um arquivo ou pasta
CTRL+Tecla Windows +F - procura por computadores em uma rede (se disponível)
Tecla Windows +L - trava o acesso ao computador ou alterna entre usuários
Tecla Windows +R - abre a caixa de diálogo Executar
Tecla Windows +T - alterna entre programas na barra de tarefas
Tecla Windows +TAB - alterna entre programas na barra de tarefas quando o Windows Flip 3-D estiver ativado
CTRL+Tecla Windows +TAB - usa as teclas de direção para alternar entre programas na barra de tarefas quando o Windows Flip 3-D estiver ativado
Tecla Windows +Barra de Espaço - traz todos os gadgets para a frente e seleciona o Windows Sidebar
Tecla Windows +G - alternar entre os gadgets do Sidebar
Tecla Windows +U - abrir a Central de Facilidade de Acesso
Tecla Windows +X - abrir a Central de Mobilidade do Windows
Tecla Windows com qualquer tecla numérica - abrir o ícone de início rápido (ao lado do menu Iniciar) que está na posição relativa a esse número. Por
exemplo, a Tecla Windows +1 abre o primeiro programa que estiver na barra de início rápido
Atalhos do Windows Explorer:
CTRL+N - abrir uma nova janela
END - mostra o final da janela ativa
HOME - mostra o início da janela ativa
F11 - maximiza ou minimiza a janela ativa
NUM LOCK+Asterisco (*) do teclado numérico - mostra todas as subpastas guardadas dentro da pasta selecionada
NUM LOCK+Sinal de mais (+) do teclado numérico - mostra o conteúdo da pasta selecionada
NUM LOCK+Sinal de menos (-) do teclado numérico - recolhe a pasta selecionada
Seta para a esquerda - recolhe a seleção atual (se estiver expandida) ou seleciona a pasta um nível acima
ALT+Seta para a esquerda - visualizar pasta anterior
Seta para a direita - mostra a seleção atual (se estiver recolhida) ou seleciona a primeira subpasta
ALT+Seta para a direita - visualizar próxima pasta
CTRL+"rodinha" do mouse – alterar a aparência e o tamanho dos ícones
ALT+D - seleciona a barra de endereços
Atalhos do Sidebar:
Tecla Windows +G - alterna entre gadgets do Sidebar
TAB - alterna entre os controles so Sidebar
Atalhos da Galeria de Fotos do Windows:
CTRL+F - abre o painel Corrigir
CTRL+P - imprime o arquivo selecionado
ENTER - visualiza o arquivo selecionado em tamanho maior
CTRL+I - abre ou fecha o painel Detalhes
CTRL+Ponto (.) - rotaciona a imagem em sentido horário
CTRL+Vírgula (,) - rotaciona a imagem em sentido anti-horário
F2 - renomear o item selecionado
CTRL+E - procura por um item
ALT+Seta para a esquerda - volta
ALT+Seta para a direita - avança
Sinal de mais (+) - Zoom para mais perto ou aumentar thumbnail
Sinal de menos (-) - Zoom para mais longe ou diminuir thumbnail
CTRL+"rodinha" do mouse - alterna o tamanho da imagem ou thumbnail
CTRL+B - melhor tamanho possível
Seta para a esquerda - seleciona o item anterior
Seta para baixo - seleciona o próximo item ou linha
Seta para cima - item anterior (quadro) ou linha anterior (thumbnail)
PAGE UP - tela anterior
PAGE DOWN - próxima tela
HOME - seleciona o primeiro item
END - seleciona o último item
DELETE - move o item selecionado para o lixeira
SHIFT+DELETE - apaga permanentemente o item selecionado
Seta para a esquerda - recolher nó
Seta para a direita - expandir nó
Atalhos para o Windows Movie Maker:
J - volta um frame
K - pausa
L - avança um frame
I - marca um ponto de edição inicial
O - marca um ponto de edição final
M - divide um clip
HOME - pára e "rebobina" até o ponto de edição inicial
ALT+Seta para a direita - próximo frame
ALT+Seta para a esquerda - frame anterior
CTRL+K - pára e "rebobina" até o início
CTRL+P – reproduz ("toca") a partir do ponto atual
END - move até o ponto de edição final
PAGE UP - procura o primeiro ponto anterior de divisão
PAGE DOWN - procura o primeiro ponto posterior de divisão
Atalhos da Ajuda do Windows:
ALT+C - mostra o índice
ALT+N - mostra o menu de conexão, para alternar entre ajuda online e ajuda offline
F10 - mostra o menu de Opções
ALT+Seta para a esquerda - volta para tópico anterior
ALT+Seta para a direita - avança para pŕoximo tópico (desde que já tenha sido visualizado antes)
ALT+A - mostra a página de atendimento ao cliente
ALT+HOME - mostra a página inicial do centro de Ajuda e Suporte
HOME - move para o começo de um tópico
END - move para o final de um tópico
CTRL+F - busca palavras no tópico atual
CTRL+P - imprime o tópico atual
F3 - seleciona o campo do mecanismo de busca
Fonte da atualizaçao acima:
lol
Resgatando o tópico
:cry:
tava procurando justamente isso
pois meu mouse acabou de quebrar e to com preguiça de ir na rua so pra comprar outro
aprendi bastante
vlw pelo ensinamento aew
xD
